On weakly turbulent solutions to the perturbed linear Harmonic oscillator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We introduce specific solutions to the linear harmonic oscillator, named bubbles. They form resonant families of invariant tori of the linear dynamics, with arbitrarily large Sobolev norms. We use these modulated bubbles of energy to construct a class of potentials which are real, smooth, time dependent and uniformly decaying to zero with respect to time, such that the corresponding perturbed quantum harmonic oscillator admits solutions which exhibit a logarithmic growth of Sobolev norms. The resonance mechanism is explicit in space variables and produces highly oscillatory solutions. We then give several recipes to construct similar examples using more specific tools based on the continuous resonant (CR) equation in dimension two.
growthlinear.pdf (412.11 Ko) Télécharger le fichier
hal-02867631 , version 1 (14-06-2020)
Erwan Faou, Pierre Raphaël. On weakly turbulent solutions to the perturbed linear Harmonic oscillator. 2020. ⟨hal-02867631⟩
37 Consultations
73 Téléchargements
