A comparison of several fault-tolerance methods for the detection and correction of floating-point errors in matrix-matrix multiplication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
rr9351.pdf (867.93 Ko) Télécharger le fichier
hal-02867859 , version 1 (15-06-2020)
  • HAL Id : hal-02867859 , version 1
Valentin Le Fèvre, Thomas Herault, Julien Langou, Yves Robert. A comparison of several fault-tolerance methods for the detection and correction of floating-point errors in matrix-matrix multiplication. [Research Report] RR-9351, Inria - Research Centre Grenoble – Rhône-Alpes. 2020. ⟨hal-02867859⟩
47 Consultations
232 Téléchargements
