Preprints, Working Papers, ...
Constructing general rough differential equations through flow approximations
Abstract : The non-linear sewing lemma constructs flows of rough differential equations from a braod class of approximations called almost flows. We consider a class of almost flows that could be approximated by solutions of ordinary differential equations, in the spirit of the backward error analysis. Mixing algebra and analysis, a Taylor formula with remainder and a composition formula are central in the expansion analysis. With a suitable algebraic structure on the non-smooth vector fields to be integrated, we recover in a single framework several results regarding high-order expansions for various kind of driving paths. We also extend the notion of driving rough path. We also introduce as an example a new family of branched rough paths, called aromatic rough paths modeled after aromatic Butcher series.
Document type :
Complete list of metadata
Cited literature [47 references]  Display  Hide  Download
https://hal.inria.fr/hal-02871886
Contributor : Antoine Lejay <>
Submitted on : Tuesday, August 4, 2020 - 6:52:09 PM
Last modification on : Tuesday, May 18, 2021 - 2:14:03 PM
Generalized_RDE_R0.pdf
Identifiers
  • HAL Id : hal-02871886, version 2
  • ARXIV : 2006.10309
Citation
Antoine Lejay. Constructing general rough differential equations through flow approximations. 2020. ⟨hal-02871886v2⟩
Share
Metrics
Record views
73
Files downloads
272
