Initial Steps Towards Infrastructuring Body-Centric Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Amir Zare Pashaei
  • Fonction : Auteur
  • PersonId : 1073592
Ilja Smorgun
  • Fonction : Auteur
David Lamas
  • Fonction : Auteur
Digital technologies are moving towards the human body. Designing for the body is commonly dubbed as body-centric computing (BCC) and includes two sides: (1) the neuro-science side; (2) the technical side mainly focuses on establishing and enabling the interactions. A conceptual framework enabling the systematic design and development of body-centric applications is introduced. Its novelty and importance are assessed within a set of application scenarios.
488595_1_En_53_Chapter.pdf (137.85 Ko) Télécharger le fichier
hal-02878648 , version 1 (23-06-2020)
Paternité
Amir Zare Pashaei, Ilja Smorgun, David Lamas, Vladimir Tomberg. Initial Steps Towards Infrastructuring Body-Centric Computing. 17th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2019, Paphos, Cyprus. pp.640-643, ⟨10.1007/978-3-030-29390-1_53⟩. ⟨hal-02878648⟩
17 Consultations
15 Téléchargements
