Transparency Heuristic: Effect of Implicitness of Online Data Acquisition on Sensitivity Perception - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a study that investigates whether the transparency of the data acquisition technique can work as a heuristic when making evaluations about data protection and sensitivity. The study (N = 40) compares an explicit data acquisition technique (questionnaires) with an implicit one (eye-tracker) and varies also the actual sensitivity of the data collected (popularity evaluation vs. usability evaluation). The results suggest that, when judging general data sensitivity, the transparency of the data collection procedure might work as a heuristic; instead if more specific judgments or decisions are asked this effect is not observed. Implications are discussed.
488595_1_En_61_Chapter.pdf (303.14 Ko) Télécharger le fichier
hal-02878652 , version 1 (23-06-2020)
Paternité
Mariavittoria Masotina, Patrik Pluchino, Francesca Freuli, Luciano Gamberini, Anna Spagnolli. Transparency Heuristic: Effect of Implicitness of Online Data Acquisition on Sensitivity Perception. 17th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2019, Paphos, Cyprus. pp.676-679, ⟨10.1007/978-3-030-29390-1_61⟩. ⟨hal-02878652⟩
26 Consultations
20 Téléchargements
