pyts: A Python Package for Time Series Classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2020
pyts is an open-source Python package for time series classification. This versatile toolbox provides implementations of many algorithms published in the literature, preprocessing functionalities, and data set loading utilities. pyts relies on the standard scientific Python packages numpy, scipy, scikit-learn, joblib, and numba, and is distributed under the BSD-3-Clause license. Documentation contains installation instructions, a detailed user guide, a full API description, and concrete self-contained examples. Source code and documentation can be downloaded from https://github.com/johannfaouzi/pyts.
Autres [stat.ML]
19-763.pdf (171.48 Ko) Télécharger le fichier
hal-02883389 , version 1 (29-06-2020)
  • HAL Id : hal-02883389 , version 1
Johann Faouzi, Hicham Janati. pyts: A Python Package for Time Series Classification. Journal of Machine Learning Research, 2020, 21, pp.1 - 6. ⟨hal-02883389⟩
450 Consultations
1983 Téléchargements
