Tslearn, A Machine Learning Toolkit for Time Series Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2020
tslearn is a general-purpose Python machine learning library for time series that offers tools for pre-processing and feature extraction as well as dedicated models for clustering, classification and regression. It follows scikit-learn's Application Programming Interface for transformers and estimators, allowing the use of standard pipelines and model selection tools on top of tslearn objects. It is distributed under the BSD-2-Clause license, and its source code is available at https://github.com/tslearn-team/tslearn.
Autres [stat.ML]
20-091.pdf (661.82 Ko) Télécharger le fichier
hal-02883390 , version 1 (29-06-2020)
  • HAL Id : hal-02883390 , version 1
Romain Tavenard, Johann Faouzi, Gilles Vandewiele, Felix Divo, Guillaume Androz, et al.. Tslearn, A Machine Learning Toolkit for Time Series Data. Journal of Machine Learning Research, 2020, 21, pp.1 - 6. ⟨hal-02883390⟩
776 Consultations
2848 Téléchargements
