Quantum limits of sub-Laplacians via joint spectral calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We establish two results concerning the Quantum Limits (QLs) of some sub-Laplacians. First, under a commutativity assumption on the vector fields involved in the definition of the sub- Laplacian, we prove that it is possible to split any QL into several pieces which can be studied separately, and which come from well-characterized parts of the associated sequence of eigenfunctions. Secondly, building upon this result, we study in detail the QLs of a particular family of sub-Laplacians defined on products of compact quotients of Heisenberg groups. We express the QLs through a disintegration of measure result which follows from a natural spectral decomposition of the sub-Laplacian in which harmonic oscillators appear. Both results are based on the construction of an adequate elliptic operator commuting with the sub-Laplacian, and on the associated joint spectral calculus. They illustrate the fact that, because of the possible high degeneracies in the spectrum, the spectral theory of sub-Laplacians is very rich.
cyril_final.pdf (678.54 Ko) Télécharger le fichier
hal-02886099 , version 1 (01-07-2020)
hal-02886099 , version 2 (08-12-2020)
hal-02886099 , version 3 (02-04-2023)
Cyril Letrouit. Quantum limits of sub-Laplacians via joint spectral calculus. 2023. ⟨hal-02886099v3⟩
127 Consultations
166 Téléchargements
