NeuMiss networks: differential programming for supervised learning with missing values - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The presence of missing values makes supervised learning much more challenging. Indeed, previous work has shown that even when the response is a linear function of the complete data, the optimal predictor is a complex function of the observed entries and the missingness indicator. As a result, the computational or sample complexities of consistent approaches depend on the number of missing patterns, which can be exponential in the number of dimensions. In this work, we derive the analytical form of the optimal predictor under a linearity assumption and various missing data mechanisms including Missing at Random (MAR) and self-masking (Missing Not At Random). Based on a Neumann-series approximation of the optimal predictor, we propose a new principled architecture, named NeuMiss networks. Their originality and strength come from the use of a new type of non-linearity: the multiplication by the missingness indicator. We provide an upper bound on the Bayes risk of NeuMiss networks, and show that they have good predictive accuracy with both a number of parameters and a computational complexity independent of the number of missing data patterns. As a result they scale well to problems with many features, and remain statistically efficient for medium-sized samples. Moreover, we show that, contrary to procedures using EM or imputation, they are robust to the missing data mechanism, including difficult MNAR settings such as self-masking.
main.pdf (4.06 Mo) Télécharger le fichier
hal-02888867 , version 1 (03-07-2020)
hal-02888867 , version 2 (12-10-2020)
hal-02888867 , version 3 (13-10-2020)
Marine Le Morvan, Julie Josse, Thomas Moreau, Erwan Scornet, Gaël Varoquaux. NeuMiss networks: differential programming for supervised learning with missing values. Advances in Neural Information Processing Systems 33, Dec 2020, Vancouver, Canada. ⟨hal-02888867v2⟩
1031 Consultations
354 Téléchargements
