IPANEMAP: Integrative Probing Analysis of Nucleic Acids Empowered by Multiple Accessibility Profiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
The manual production of reliable RNA structure models from chemical probing experiments benefits from the integration of information derived from multiple protocols and reagents. However, the interpretation of multiple probing profiles remains a complex task, hindering the quality and reproducibility of modeling efforts. We introduce IPANEMAP, the first automated method for the modeling of RNA structure from multiple probing reactivity profiles. Input profiles can result from experiments based on diverse protocols, reagents, or collection of variants, and are jointly analyzed to predict the dominant conformations of an RNA. IPANEMAP combines sampling, clustering, and multi-optimization, to produce secondary structure models that are both stable and well-supported by experimental evidences. The analysis of multiple reactivity profiles, both publicly available and produced in our study, demonstrates the good performances of IPANEMAP, even in a mono probing setting. It confirms the potential of integrating multiple sources of probing data, informing the design of informative probing assays. Availability: IPANEMAP is freely downloadable at https://github.com/afafbioinfo/IPANEMAP Contact: yann.ponty@lix.polytechnique.fr Supplementary information available at NAR online.
IPANEMAP(5).pdf (1.01 Mo) Télécharger le fichier
hal-02889041 , version 1 (03-07-2020)
hal-02889041 , version 2 (04-07-2020)
hal-02889041 , version 3 (30-07-2020)
  • HAL Id : hal-02889041 , version 1
Afaf Saaidi, Delphine M Allouche, Mireille Regnier, Bruno Sargueil, Yann Ponty. IPANEMAP: Integrative Probing Analysis of Nucleic Acids Empowered by Multiple Accessibility Profiles. 2020. ⟨hal-02889041v1⟩
108 Consultations
484 Téléchargements
