Closing the Gap in Linear Bilevel Optimization: A New Valid Primal-Dual Inequality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Linear bilevel optimization problems are often tackled by replacing the linear lower-level problem with its Karush-Kuhn-Tucker (KKT) conditions. The resulting single-level problem can be solved in a branch-and-bound fashion by branching on the complementarity constraints of the lower-level problem's optimality conditions. While in mixed-integer single-level optimization branch-and-cut has proven to be a powerful extension of branch-and-bound, in linear bilevel optimization not too many bilevel-tailored valid inequalities exist. In this paper, we briefly review existing cuts for linear bilevel problems and introduce a new valid inequality that exploits the strong duality condition of the lower level. We further discuss strengthened variants of the inequality that can be derived from McCormick envelopes. In a computational study, we show that the new valid inequalities can help to close the optimality gap very effectively on a large test set of linear bilevel instances.
bilevel_lp_lp_branch_and_cut_preprint.pdf (542.36 Ko) Télécharger le fichier
hal-02889276 , version 1 (03-07-2020)
hal-02889276 , version 2 (16-09-2020)
  • HAL Id : hal-02889276 , version 1
Thomas Kleinert, Martine Labbé, Fränk Plein, Martin Schmidt. Closing the Gap in Linear Bilevel Optimization: A New Valid Primal-Dual Inequality. 2020. ⟨hal-02889276v1⟩
251 Consultations
295 Téléchargements
