A discrete Weber inequality on three-dimensional hybrid spaces with application to the HHO approximation of magnetostatics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We prove a discrete version of the first Weber inequality on three-dimensional hybrid spaces spanned by vectors of polynomials attached to the elements and faces of a polyhedral mesh. We then introduce two Hybrid High-Order methods for the approximation of the magnetostatic model, in both its (first-order) field and (second-order) vector potential formulations. These methods are applicable on general polyhedral meshes with star-shaped elements, and allow for arbitrary orders of approximation. Leveraging the previously established discrete Weber inequality, we perform a comprehensive analysis of the two methods. We finally validate them on a set of test-cases.
magnethho.pdf (413.82 Ko) Télécharger le fichier
hal-02892526 , version 1 (07-07-2020)
hal-02892526 , version 2 (14-06-2021)
hal-02892526 , version 3 (24-10-2021)
  • HAL Id : hal-02892526 , version 1
Florent Chave, Daniele Antonio Di Pietro, Simon Lemaire. A discrete Weber inequality on three-dimensional hybrid spaces with application to the HHO approximation of magnetostatics. 2020. ⟨hal-02892526v1⟩
300 Consultations
190 Téléchargements
