Modified parareal method for solving the two-dimensional nonlinear shallow water equations using finite volumes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail SMAI Journal of Computational Mathematics Année : 2020
In this work, the POD-DEIM-based parareal method introduced in [6] is implemented for the resolution of the two-dimensional nonlinear shallow water equations using a finite volume scheme. This method is a variant of the traditional parareal method, first introduced by [19], that improves the stability and convergence for nonlinear hyperbolic problems, and uses reduced-order models constructed via the Proper Orthogonal Decomposition-Discrete Empirical Interpolation Method (POD-DEIM) applied to snapshots of the solution of the parareal iterations. We propose a modification of this parareal method for further stability and convergence improvements. It consists in enriching the snapshots set for the POD-DEIM procedure with extra snapshots whose computation does not require any additional computational cost. The performances of the classical parareal method, the POD-DEIM-based parareal method and our proposed modification are compared using numerical tests with increasing complexity. Our modified method shows a more stable behaviour and converges in fewer iterations than the other two methods.
JCM_parareal_SWE.pdf (761.32 Ko) Télécharger le fichier
hal-02894841 , version 1 (09-07-2020)
hal-02894841 , version 2 (16-11-2021)
  • HAL Id : hal-02894841 , version 1
Joao Guilherme Caldas Steinstraesser, Vincent Guinot, Antoine Rousseau. Modified parareal method for solving the two-dimensional nonlinear shallow water equations using finite volumes. In press. ⟨hal-02894841v1⟩
Collections
SW2D-SOFT
366 Consultations
416 Téléchargements
