Depth-Adaptive Neural Networks from the Optimal Control viewpoint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In recent years, deep learning has been connected with optimal control as a way to define a notion of a continuous underlying learning problem. In this view, neural networks can be interpreted as a discretization of a parametric Ordinary Differential Equation which, in the limit, defines a continuous-depth neural network. The learning task then consists in finding the best ODE parameters for the problem under consideration, and their number increases with the accuracy of the time discretization. Although important steps have been taken to realize the advantages of such continuous formulations, most current learning techniques fix a discretization (i.e. the number of layers is fixed). In this work, we propose an iterative adaptive algorithm where we progressively refine the time discretization (i.e. we increase the number of layers). Provided that certain tolerances are met across the iterations, we prove that the strategy converges to the underlying continuous problem. One salient advantage of such a shallow-to-deep approach is that it helps to benefit in practice from the higher approximation properties of deep networks by mitigating over-parametrization issues. The performance of the approach is illustrated in several numerical examples.
AM2020.pdf (2.14 Mo) Télécharger le fichier
hal-02897466 , version 1 (12-07-2020)
hal-02897466 , version 2 (19-04-2023)
Joubine Aghili, Olga Mula. Depth-Adaptive Neural Networks from the Optimal Control viewpoint. 2020. ⟨hal-02897466v1⟩
208 Consultations
232 Téléchargements
