Playing with the Tower of Hanoi Formally - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
The Tower of Hanoi is a typical example that illustrates all the power of recursion in programming. In this paper, we show that it is also a very nice example for inductive proofs and formal verification. We present some non-trivial results about it that have been formalised in the Coq proof assistant.
Note.pdf (316.26 Ko) Télécharger le fichier
hal-02903548 , version 2 (21-07-2020)
  • HAL Id : hal-02903548 , version 2
Laurent Théry. Playing with the Tower of Hanoi Formally. 2020. ⟨hal-02903548⟩
157 Consultations
1076 Téléchargements
