Thermo-mechanical transport in rotor chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Physics Année : 2021
We study the macroscopic profiles of temperature and angular momentum in the stationary state of chains of rotors under a thermo-mechanical forcing applied at the boundaries. These profiles are solutions of a system of diffusive partial differential equations with boundary conditions determined by the thermo-mechanical forcing. Instead of expensive Monte Carlo simulations of the underlying microscopic dynamics, we perform extensive numerical simulations based on a finite difference method for the system of partial differential equations describing the macroscopic steady state. We first present a formal derivation of these stationary equations based on a linear response argument and local equilibrium assumptions. We then study various properties of the solutions to these equations. This allows to characterize the regime of parameters leading to uphill diffusion, a situation where the energy flows in the direction of the gradient of temperature; and to identify regions of parameters corresponding to a negative thermal conductivity (i.e. a positive linear response to a gradient of temperature). The agreement with previous results obtained by numerical simulation of the microscopic physical system confirms the validity of the macroscopic equations we derive.
hal-02904454 , version 1 (22-07-2020)
Alessandra Iacobucci, Stefano Olla, Gabriel Stoltz. Thermo-mechanical transport in rotor chains. Journal of Statistical Physics, 2021, 183, pp.article number 26. ⟨hal-02904454⟩
68 Consultations
0 Téléchargements
