A New Way to Classify Physical Effects for Ontology Instantiation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As one of the most important knowledge sources of TRIZ, the collection of Physical effects is currently searched in a very basic way. In order to enhance its use, different proposals have been brought to the community to classify effects into different categories. Among them, a rule-based approach classified the collection of physical effects into four categories and built a set of rules to facilitate its direct use. However, this approach is not robust enough due to the lack of instances of physical effects. In this paper, we propose a new approach to classify physical effects in order instantiate the existing ontology. In addition, preliminary results are presented to demonstrate the feasibility of the approach. The results brought us evidences that we facilitate the direct access to the collection of physical effects.
489563_1_En_7_Chapter.pdf (833.15 Ko) Télécharger le fichier
hal-02905523 , version 1 (23-07-2020)
Paternité
Pei Zhang, Denis Cavallucci, Cecilia Zanni-Merk. A New Way to Classify Physical Effects for Ontology Instantiation. 19th International TRIZ Future Conference (TFC), Oct 2019, Marrakesh, Morocco. pp.70-78, ⟨10.1007/978-3-030-32497-1_7⟩. ⟨hal-02905523⟩
25 Consultations
30 Téléchargements
