Classification of TRIZ Inventive Principles and Sub-principles for Process Engineering Problems
The paper proposes a classification approach of 40 Inventive Principles with an extended set of 160 sub-principles for process engineering, based on a thorough analysis of 155 process intensification technologies, 200 patent documents, 6 industrial case studies applying TRIZ, and other sources. The authors define problem-specific sub-principles groups as a more precise and productive ideation technique, adaptable for a large diversity of problem situations, and finally, examine the anticipated variety of ideation using 160 sub-principles with the help of MATCEM-IBD fields.
Informatique [cs]
