Classification of TRIZ Inventive Principles and Sub-principles for Process Engineering Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper proposes a classification approach of 40 Inventive Principles with an extended set of 160 sub-principles for process engineering, based on a thorough analysis of 155 process intensification technologies, 200 patent documents, 6 industrial case studies applying TRIZ, and other sources. The authors define problem-specific sub-principles groups as a more precise and productive ideation technique, adaptable for a large diversity of problem situations, and finally, examine the anticipated variety of ideation using 160 sub-principles with the help of MATCEM-IBD fields.
489563_1_En_26_Chapter.pdf (311.16 Ko) Télécharger le fichier
hal-02905529 , version 1 (23-07-2020)
Paternité
Arun Prasad Chandra Sekaran, Pavel Livotov, - Mas’udah. Classification of TRIZ Inventive Principles and Sub-principles for Process Engineering Problems. 19th International TRIZ Future Conference (TFC), Oct 2019, Marrakesh, Morocco. pp.314-327, ⟨10.1007/978-3-030-32497-1_26⟩. ⟨hal-02905529⟩
45 Consultations
120 Téléchargements
