Abnormal acoustic transmission in a waveguide with perforated screens - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mécanique Année : 2021
We consider the propagation of the piston mode in an acoustic waveguide obstructed by two screens with small holes. In general, due to the features of the geometry, almost no energy of the incident wave is transmitted through the structure. The goal of this article is to show that tuning carefully the distance between the two screens, which form a resonator, one can get almost complete transmission. We obtain an explicit criterion, not so obvious to intuit, for this phenomenon to happen. Numerical experiments illustrate the analysis.
ChNa.pdf (1.03 Mo) Télécharger le fichier
hal-02907039 , version 1 (27-07-2020)
Lucas Chesnel, Sergei Nazarov. Abnormal acoustic transmission in a waveguide with perforated screens. Comptes Rendus. Mécanique, 2021, ⟨10.5802/crmeca.70⟩. ⟨hal-02907039⟩
68 Consultations
49 Téléchargements
