Existence of strong solutions for a system of interaction between a compressible viscous fluid and a wave equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinearity Année : 2021
In this article, we consider a fluid-structure interaction system where the fluid is viscous and compressible and where the structure is a part of the boundary of the fluid domain and is deformable. The fluid is governed by the barotropic compressible Navier-Stokes system whereas the structure displacement is described by a wave equation. We show that the corresponding coupled system admits a unique strong solution for an initial fluid density and an initial fluid velocity in $H^3$ and for an initial deformation and an initial deformation velocity in $H^4$ and $H^3$ respectively. The reference configuration for the fluid domain is a rectangular cuboid with the elastic structure being the top face. We use a modified Lagrangian change of variables to transform the moving fluid domain into the rectangular cuboid and then analyze the corresponding linear system coupling a transport equation (for the density), a heat-type equation, and a wave equation. The corresponding results for this linear system and estimations of the coefficients coming from the change of variables allow us to perform a fixed point argument and to prove the existence and uniqueness of strong solutions for the nonlinear system, locally in time.
CNS-Wave-MRT.pdf (374.44 Ko) Télécharger le fichier
hal-02908420 , version 1 (29-07-2020)
Debayan Maity, Arnab Roy, Takéo Takahashi. Existence of strong solutions for a system of interaction between a compressible viscous fluid and a wave equation. Nonlinearity, 2021, ⟨10.1088/1361-6544/abe696⟩. ⟨hal-02908420⟩
120 Consultations
120 Téléchargements
