Explaining Multicriteria Decision Making with Formal Concept Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multicriteria decision making aims at helping a decision maker choose the best solutions among alternatives compared against multiple conflicting criteria. The reasons why an alternative is considered among the best are not always clearly explained. In this paper, we propose an approach that uses formal concept analysis and background knowledge on the criteria to explain the presence of alternatives on the Pareto front of a multicriteria decision problem.
CLA_2020___MCDM.pdf (416.94 Ko) Télécharger le fichier
hal-02909383 , version 1 (30-07-2020)
hal-02909383 , version 2 (28-03-2021)
  • HAL Id : hal-02909383 , version 1
Alexandre Bazin, Miguel Couceiro, Marie-Dominique Devignes, Amedeo Napoli. Explaining Multicriteria Decision Making with Formal Concept Analysis. Concept Lattices and Applications 2020, Jun 2020, Tallinn, Estonia. ⟨hal-02909383v1⟩
237 Consultations
211 Téléchargements
