Local transparent boundary conditions for wave propagation in fractal trees (ii): error and complexity analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2022
This work is dedicated to a refined error analysis of the high-order transparent boundary conditions introduced in the companion work [8] for the weighted wave equation on a fractal tree. The construction of such boundary conditions relies on truncating the meromorphic series that represents the symbol of the Dirichlet-to-Neumann operator. The error induced by the truncation depends on the behaviour of the eigenvalues and the eigenfunctions of the weighted Laplacian on a self-similar metric tree. In this work we quantify this error by computing asymptotics of the eigenvalues and bounds for Neumann traces of the eigenfunctions. We prove the sharpness of the obtained bounds for a class of self-similar trees.
main_report.pdf (530.43 Ko) Télécharger le fichier
hal-02909750 , version 1 (31-07-2020)
hal-02909750 , version 2 (03-08-2020)
Patrick Joly, Maryna Kachanovska. Local transparent boundary conditions for wave propagation in fractal trees (ii): error and complexity analysis. SIAM Journal on Numerical Analysis, 2022, 60 (2), ⟨10.1137/20M1357524⟩. ⟨hal-02909750v2⟩
144 Consultations
123 Téléchargements
