Conference papers
Combinatorial Tiling for Sparse Neural Networks
Abstract : Sparse deep neural networks (DNNs) emerged as the result of search for networks with less storage and lower computational complexity. The sparse DNN inference is the task of using such trained DNN networks to classify a batch of input data. We propose an efficient, hybrid model- and data-parallel DNN inference using hypergraph models and partitioners. We exploit tiling and weak synchronization to increase cache reuse, hide load imbalance, and hide synchronization costs. Finally, a blocking approach allows application of this new hybrid inference procedure for deep neural networks. We initially experiment using the hybrid tiled inference approach only, using the first five layers of networks from the IEEE HPEC 2019 Graph Challenge, and attain up to 2x speedup versus a data-parallel baseline
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-02910997
Contributor : Bora Uçar Connect in order to contact the contributor
Submitted on : Thursday, September 3, 2020 - 9:23:32 PM
Last modification on : Friday, September 30, 2022 - 4:12:24 AM
File
sparseNetworks.pdf
Identifiers
  • HAL Id : hal-02910997, version 3
Collections
Citation
Filip Pawłowski, Rob H Bisseling, Bora Uçar, Albert-Jan N Yzelman. Combinatorial Tiling for Sparse Neural Networks. 2020 IEEE High Performance Extreme Computing (virtual conference), Sep 2020, Waltham, MA, United States. ⟨hal-02910997v3⟩
Share
Metrics
Record views
263
Files downloads
429
