CERTIFICATION FOR POLYNOMIAL SYSTEMS VIA SQUARE SUBSYSTEMS
We consider numerical certification of approximate solutions to a system of
polynomial equations with more equations than unknowns by first certifying solutions
to a square subsystem. We give several approaches that certifiably select which are
solutions to the original overdetermined system. These approaches each use different
additional information for this certification, such as liaison, Newton-Okounkov bodies, or
intersection theory. They may be used to certify individual solutions, reject nonsolutions,
or certify that we have found all solutions.
