MEASURING THE LOCAL NON-CONVEXITY OF REAL ALGEBRAIC CURVES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of this paper is to measure the non-convexity of compact and smooth connected components of real algebraic plane curves. We study these curves first in a general setting and then in an asymptotic one. In particular, we consider sufficiently small levels of a real bivariate polynomial in a small enough neighbourhood of a strict local minimum at the origin of the real affine plane. We introduce and describe a new combinatorial object, called the Poincaré-Reeb graph, whose role is to encode the shape of such curves and allow us to quantify their non-convexity. Moreover, we prove that in this setting the Poincaré-Reeb graph is a plane tree and can be used as a tool to study the asymptotic behaviour of level curves near a strict local minimum. Finally, using the real polar curve, we show that locally the shape of the levels stabilises and that no spiralling phenomena occur near the origin.
17.pdf (3.25 Mo) Télécharger le fichier
hal-02912362 , version 1 (05-08-2020)
  • HAL Id : hal-02912362 , version 1
Miruna-Stefana Sorea. MEASURING THE LOCAL NON-CONVEXITY OF REAL ALGEBRAIC CURVES. MEGA 2019 - International Conference on Effective Methods in Algebraic Geometry, Jun 2019, Madrid, Spain. ⟨hal-02912362⟩
Collections
MEGA MEGA2019
47 Consultations
43 Téléchargements
