First two-way laser ranging to a lunar orbiter: infrared observations from the Grasse station to LRO’s retro-reflector array - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Earth Planets and Space Année : 2020
Jean-Marie Torre
  • Fonction : Auteur
Clément Courde
Julien Chabé
Mourad Aimar
Hervé Mariey
Nicolas Maurice
  • Fonction : Auteur
Michael Barker
Dandan Mao
  • Fonction : Auteur
Daniel Cremons
  • Fonction : Auteur
Vishnu Viswanathan
Gregory Neumann
  • Fonction : Auteur
David C. Smith
  • Fonction : Auteur
  • PersonId : 839883
We present the results of the first series of successful two-way laser ranging experiments from a ground station, the Lunar Laser Ranging (LLR) station in Grasse, France, to a spacecraft at lunar distance, the Lunar Reconnaissance Orbiter (LRO). A 15 × 18 × 5 cm, 650-g array of twelve 32-mm diameter solid corner cubes is mounted on its anti-nadir deck. Ranging to this small retro-reflector array onboard a lunar orbiter from a ground station was a challenge compared to ranging to larger lunar surface retro-reflectors. Grasse measured 67 returns in two 6-min sessions on September 4, 2018. Clear returns were also recorded during two additional sessions on August 23-24, 2019 for which active slewing by LRO was performed to bring the array in view of the station. The measured echos yielded range residuals less than 3 cm (two-way time-of-flight RMS < 180 ps) relative to the reconstructed LRO trajectory. This experiment provides a new method of verifying theories of dust accumulation over decades on the lunar surface. It also showed that the use of similar arrays onboard future lunar landers and orbiters can support LLR lunar science goals, particularly with landing sites near the lunar limbs and poles, which would have better sensitivity to lunar orientation.
s40623-020-01243-w.pdf (2.73 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-02913117 , version 1 (15-04-2021)
Paternité
Erwan Mazarico, Xiaoli Sun, Jean-Marie Torre, Clément Courde, Julien Chabé, et al.. First two-way laser ranging to a lunar orbiter: infrared observations from the Grasse station to LRO’s retro-reflector array. Earth Planets and Space, 2020, 72 (1), pp.113. ⟨10.1186/s40623-020-01243-w⟩. ⟨hal-02913117⟩
194 Consultations
43 Téléchargements
