Evaluating Computation and Data Placements in Edge Infrastructures through a Common Simulator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Scheduling computational jobs with data-sets dependencies is an important challenge of edge computing infras-tructures. Although several strategies have been proposed, they have been evaluated through ad-hoc simulator extensions that are, when available, usually not maintained. This is a critical problem because it prevents researchers to-easily-perform fair comparisons between different proposals. In this paper, we propose to address this limitation by presenting a simulation engine dedicated to the evaluation and comparison of scheduling and data movement policies for edge computing use-cases. Built upon the Batsim/SimGrid toolkit, our tool includes an injector that allows the simulator to replay a series of events captured in real infrastructures. It also includes a controller that supervises storage entities and data transfers during the simulation, and a plug-in system that allows researchers to add new models to cope with the diversity of edge computing devices. We demonstrate the relevance of such a simulation toolkit by studying two scheduling strategies with four data movement policies on top of a simulated version of the Qarnot Computing platform, a production edge infrastructure based on smart heaters. We chose this use-case as it illustrates the heterogeneity as well as the uncertainties of edge infrastructures. Our ultimate goal is to gather industry and academics around a common simulator so that efforts made by one group can be factorised by others.
main.pdf (363.08 Ko) Télécharger le fichier
hal-02915346 , version 1 (14-08-2020)
Anderson Andrei da Silva, Clément Mommessin, Pierre Neyron, Denis Trystram, Adwait Bauskar, et al.. Evaluating Computation and Data Placements in Edge Infrastructures through a Common Simulator. SBAC-PAD 2020 - IEEE 32nd International Symposium on Computer Architecture and High Performance Computing, Sep 2020, Porto, Portugal. pp.1-8, ⟨10.1109/SBAC-PAD49847.2020.00020⟩. ⟨hal-02915346⟩
285 Consultations
466 Téléchargements
