Atlas: Exploration and Mapping with a Sparse Swarm of Networked IoT Robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Exploration and mapping is a fundamental capability of a swarm of robots: robots enter an unknown area, explore it, and collectively build a map of it. This capability is important regardless of whether the robots are crawling, flying,or swimming. Existing exploration and mapping algorithms tend to either be inefficient, or rely on having a dense swarm of robots.This paper introduces Atlas, an exploration and mapping algorithm for sparse swarms of robots, which completes a full exploration even in the extreme case of a single robot. We developan open-source simulator and show that Atlas out performs the state-of-the-art in terms of exploration speed and completeness of the resulting map.
abu-aisheh20explore.pdf (235.94 Ko) Télécharger le fichier
hal-02916797 , version 1 (18-08-2020)
  • HAL Id : hal-02916797 , version 1
Razanne Abu-Aisheh, Francesco Bronzino, Myriana Rifai, Brian Kilberg, Kris Pister, et al.. Atlas: Exploration and Mapping with a Sparse Swarm of Networked IoT Robots. Wi-DroIT 2020 - Workshop on Wireless Sensors and Drones in Internet of Things, Jun 2020, Los Angeles, CA / Virtual, United States. ⟨hal-02916797⟩
139 Consultations
590 Téléchargements
