Visual Servoing
Visual servoing refers to the use of visual data as input of real-time closed-loop control schemes for controlling the motion of a dynamic system, a robot typically. It can be defined as sensor-based control from a vision sensor and relies on techniques from image processing, computer vision, and control theory.
Domains
Robotics [cs.RO]
