Effect of carbon nanotubes on the in-plane dynamic behavior of a carbon/epoxy composite under high strain rate compression using SHPB - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Smart Materials and Structures Année : 2020
Fiber reinforced composites have wide structural applications and vast research has been going on to improve their mechanical performance when subjected to quasi-static loading but, study of their dynamic behavior is still underdeveloped. For this reason, scientists have been continuously working on developing methods to improve their dynamic characteristics and addition of nanofillers suchs as Carbon Nanotubes (CNTs) as reinforcement is considered a possible solution for developing future generation high-quality fiber reinforced nanocomposites. In this study, composite specimens are manufactured using Epon 862 Epoxy resin and T300 6 k carbon fibers, and each specimen contained different weight percentages of multi-walled Carbon nanotubes (MWCNTs) i.e. 0% as a reference, 0.5%, and 2%. Specimens were tested experimentally using the Split Hopkinson pressure bar device (SHPB) under different pressures to examine their dynamic response and damage behavior at high strain rates. During the dynamic compression tests, a high-speed camera was used to monitor and record the damage kinetics. The experimental characterization showed that the integration of CNTs in matrix has greatly influenced the dynamic response and damage mechanism of the Carbon Fiber Reinforced Polymers composite (CFRP). Mechanical behavior of specimens with each percentage demonstrated the enhancement of the mechanical properties and showed the increase of the dynamic characteristics and fracture resistance because of the increase in stiffness of matrix material and interfacial bonding between matix and fiber reinforcement.
Chihi2020.pdf (1.69 Mo) Télécharger le fichier
hal-02924116 , version 1 (16-06-2021)
Paternité
Manel Chihi, Mostapha Tarfaoui, Yumna Qureshi, Chokri Bouraoui, Hamza Benyahia. Effect of carbon nanotubes on the in-plane dynamic behavior of a carbon/epoxy composite under high strain rate compression using SHPB. Smart Materials and Structures, 2020, 29 (8), pp.085012. ⟨10.1088/1361-665X/ab83cd⟩. ⟨hal-02924116⟩
134 Consultations
204 Téléchargements
