Rate-Storage Regions for Extractable Source Coding with Side Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Communication Année : 2019
This papers considers the coding of a source X with J decoders, each having access to a different side information Y (j). We define a new source coding problem called Extractable Source Coding with Side Information (ESC-SI). In this problem, the server stores one single coded description of the source, from which J descriptions can be extracted without re-encoding, depending on the side information available at the decoder. We want to minimize both the storage rate of the source on the server, and the J transmission rates from the server to the decoders. We provide the achievable storage-transmission rate regions for lossless source coding of general, non i.i.d., non-ergodic sources, and the achievable storage-transmission rate-distortion regions for lossy source coding for non i.i.d. Gaussian sources. The regions obtained for such general source models provide insightful design guidelines for practical applications.
Dupraz20PhyCom.pdf (504.31 Ko) Télécharger le fichier
hal-02925026 , version 2 (03-12-2019)
hal-02925026 , version 1 (28-08-2020)
Elsa Dupraz, Aline Roumy, Thomas Maugey, Michel Kieffer. Rate-Storage Regions for Extractable Source Coding with Side Information. Physical Communication, 2019, ⟨10.1016/j.phycom.2019.100845⟩. ⟨hal-02925026v1⟩
84 Consultations
335 Téléchargements
