A thermal energy harvester using LaFeSi magnetocaloric materials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2021
A thermomagnetic generator (TMG) using an Halbach structure as a field source and a first order LaFeSi magnetocaloric material (MCM) from Vacuumschmelze as active substance, is presented. The MCM, suspended on a cantilever beam self oscillates between a hot source and a heat sink. The mechanical energy associated with the oscillation is harvested and converted into electricity using piezoelectric materials. This system is working between a 18°C cold end, and a 56°C heat source (i.e. over a temperature difference between reservoirs ∆Tres = 38°C) and shows a power of 0.12µW (6.8 µW per 1 cm 3 of MCM). We present and discuss a detailed analysis of the thermodynamic cycle underpinning the device mechanism, relying on direct measurements on the working prototype and on a full laboratory characterization of the MCM. Although our system shows a state-of-the-art power output, our analysis gives useful clues towards further performance improvements.
Smail_Intermag (7).pdf (961.86 Ko) Télécharger le fichier
hal-02925562 , version 1 (03-12-2020)
Smail Ahmim, Morgan Almanza, Vincent Loyau, Alexandre Pasko, Frédéric Mazaleyrat, et al.. A thermal energy harvester using LaFeSi magnetocaloric materials. IEEE Transactions on Magnetics, 2021, ⟨10.1109/TMAG.2020.3008753⟩. ⟨hal-02925562⟩
401 Consultations
267 Téléchargements
