Black-box inhomogeneous preconditioning for self-consistent field iterations in density functional theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Physics: Condensed Matter Année : 2020
We propose a new preconditioner for computing the self-consistent problem in Kohn-Sham density functional theory, based on the local density of states. This preconditioner is inexpensive and able to cure the long-range charge sloshing known to hamper convergence in large, inhomogeneous systems such as clusters and surfaces. It is based on a parameter-free and physically motivated approximation to the independent-particle susceptibility operator, appropriate for both metals and insulators. It can be extended to semiconductors by using the macroscopic electronic dielectric constant as a parameter in the model. We test our preconditioner successfully on inhomogeneous systems containing metals, insulators, semiconductors and vacuum.
hal-02929951 , version 1 (04-09-2020)
Michael F. Herbst, Antoine Levitt. Black-box inhomogeneous preconditioning for self-consistent field iterations in density functional theory. Journal of Physics: Condensed Matter, 2020, 33 (8), ⟨10.1088/1361-648X/abcbdb⟩. ⟨hal-02929951⟩
68 Consultations
0 Téléchargements
