STAG3 homozygous missense variant causes primary ovarian insufficiency and male non-obstructive azoospermia - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Molecular Human Reproduction Année : 2020
Infertility, a global problem affecting up to 15% of couples, can have varied causes ranging from natural aging to the pathological development or function of the reproductive organs. One form of female infertility is premature ovarian insufficiency (POI), affecting up to 1 in 100 women and characterised by amenorrhea and elevated follicle stimulating hormone before the age of 40. POI can have a genetic basis, with over 50 causative genes identified. Non-obstructive azoospermia (NOA), a form of male infertility characterised by the absence of sperm in semen, has an incidence of 1% and is similarly heterogeneous. The genetic basis of male and female infertility is poorly understood with the majority of cases having no known cause. Here, we study a case of familial infertility including a proband with POI and her brother with NOA. We performed whole-exome sequencing (WES) and identified a homozygous STAG3 missense variant that segregated with infertility. STAG3 encodes a component of the meiosis cohesin complex required for sister chromatid separation. We report the first pathogenic homozygous missense variant in STAG3 and the first STAG3 variant associated with both male and female infertility. We also demonstrate limitations of WES for the analysis of homologous DNA sequences, with this variant being ambiguous or missed by independent WES protocols and its homozygosity only being established via long-range nested PCR.
Jaillard et al-2020-STAG3 homozygous missense variant causes primary.pdf (2.07 Mo) Télécharger le fichier
hal-02929984 , version 1 (11-09-2020)
Paternité
Sylvie Jaillard, Kenneth Mcelreavy, Gorjana Robevska, Linda Akloul, Farah Ghieh, et al.. STAG3 homozygous missense variant causes primary ovarian insufficiency and male non-obstructive azoospermia. Molecular Human Reproduction, 2020, 26 (9), pp.665-677. ⟨10.1093/molehr/gaaa050⟩. ⟨hal-02929984⟩
295 Consultations
301 Téléchargements
