Quantifying the Similarity of Non-bisimilar Labelled Transition Systems
Equivalence checking is an established technique for automatically verifying that two behavioural models (Labelled Transition Systems, LTSs) are equivalent from the point of view of an external observer. When these models are not equivalent, the checker returns a Boolean result with a counterexample, which is a sequence of actions leading to a state where the equivalence relation is not satisfied. However , this counterexample does not give any indication of how far the two LTSs are one from another. One can wonder whether they are almost identical or totally different, which is quite different from a design or debugging point of view. In this paper, we present an approach for measuring the similarity between two LTS models. The set of metrics is computed automatically using a tool we implemented. Beyond presenting the foundations of the proposed solution, we will show how it can be applied to a concrete application domain for supporting the construction of IoT applications by composition of existing devices.
Génie logiciel [cs.SE]Origine | Fichiers produits par l'(les) auteur(s) |
