Functional connectivity is preserved but reorganized across several anesthetic regimes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2020
Under anesthesia, systemic variables and CBF are modified. How does this alter the connectivity measures obtained with rs-fMRI? To tackle this question, we explored the effect of four different anesthetics on Long Evans and Wistar rats with multimodal recordings of rs-fMRI, systemic variables and CBF. After multimodal signal processing, we show that the blood-oxygen-level-dependent (BOLD) variations and functional connectivity (FC) evaluated at low frequencies (0.031-0.25 Hz) do not depend on systemic variables and are preserved across a large interval of baseline CBF values. Based on these findings, we found that most brain areas remain functionally active under any anesthetics, i.e. connected to at least one other brain area, as shown by the connectivity graphs. In addition, we quantified the influence of nodes by a measure of functional connectivity strength to show the specific areas targeted by anesthetics and compare correlation values of edges at different levels. These measures enable us to highlight the specific network alterations induced by anesthetics. Altogether, this suggests that changes in connectivity could be evaluated under anesthesia, routinely used in the control of neurological injury.
rat_physio_graphs.pdf (9.45 Mo) Télécharger le fichier
hal-02935430 , version 1 (10-09-2020)
Guillaume Jean-Paul Claude Becq, Tarik Habet, Nora Collomb, Margaux Faucher, Chantal Delon-Martin, et al.. Functional connectivity is preserved but reorganized across several anesthetic regimes. NeuroImage, 2020, 219, pp.116945. ⟨10.1016/j.neuroimage.2020.116945⟩. ⟨hal-02935430⟩
84 Consultations
46 Téléchargements
