Abstract : This paper deals with the parametric shape optimization of a simplified model of brake system under squeal noise criteria. As brake squeal phenomenon induces under-quality perception for industrial structures such as cars and trains, its understanding and management are important challenges for future systems design. Hence, we expose an optimization methodology based on meta-model for a proposed computationally expensive stability criteria representing the squeal noise. Sensitivity analysis is first conducted to assess and validate the chosen geometrical parameters. Then, a Pareto front is obtained through optimization of the system, leading to a set of optimal solutions for theconsidered multi-objective case.
https://hal.inria.fr/hal-02935546 Contributor : Laurent MevelConnect in order to contact the contributor Submitted on : Thursday, September 10, 2020 - 2:20:56 PM Last modification on : Saturday, June 18, 2022 - 3:58:29 AM Long-term archiving on: : Thursday, December 3, 2020 - 2:05:04 AM
Pradeep Mohanasundaram, Frédéric Gillot, Koji Shimoyama, Sébastien Besset. Shape optimization of a disc-pad system under squeal noise criteria. SN Applied Sciences, Springer Verlag, 2020, 2 (4), ⟨10.1007/s42452-020-2175-8⟩. ⟨hal-02935546⟩
