Shape optimization of a disc-pad system under squeal noise criteria - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SN Applied Sciences Année : 2020
This paper deals with the parametric shape optimization of a simplified model of brake system under squeal noise criteria. As brake squeal phenomenon induces under-quality perception for industrial structures such as cars and trains, its understanding and management are important challenges for future systems design. Hence, we expose an optimization methodology based on meta-model for a proposed computationally expensive stability criteria representing the squeal noise. Sensitivity analysis is first conducted to assess and validate the chosen geometrical parameters. Then, a Pareto front is obtained through optimization of the system, leading to a set of optimal solutions for theconsidered multi-objective case.
BMEN-D-19-00001_R21.pdf (2.61 Mo) Télécharger le fichier
hal-02935546 , version 1 (10-09-2020)
Pradeep Mohanasundaram, Frédéric Gillot, Koji Shimoyama, Sébastien Besset. Shape optimization of a disc-pad system under squeal noise criteria. SN Applied Sciences, 2020, 2 (4), ⟨10.1007/s42452-020-2175-8⟩. ⟨hal-02935546⟩
131 Consultations
102 Téléchargements
