A Kriging-based Interacting Particle Kalman Filter for the simultaneous estimation of temperature and emissivity in Infra-Red imaging - Archive ouverte HAL Access content directly
Conference Papers Year :
Temperature estimation through infrared thermography is facing the lack of knowledge of the observed material's emissivity. The derivation of the physical equations lead to an ill-posed problem. A new Kriged Interacting Particle Kalman Filter is proposed. A state space model relates the measurements to the temperature and the Kalman filter equations yield a filter tracking the temperature over time. Moreover, a particle filter associated to Kriging prediction is interacting with a bank of Kalman filters to estimate the time-varying parameters of the system. The efficiency of the algorithm is tested on a simulated sequence of infrared thermal images.
IFAC.pdf (981.89 Ko) Télécharger le fichier
Dates and versions
hal-02940184 , version 1 (16-09-2020)
Identifiers
  • HAL Id : hal-02940184 , version 1
Cite
Thibaud Toullier, Jean Dumoulin, Laurent Mevel. A Kriging-based Interacting Particle Kalman Filter for the simultaneous estimation of temperature and emissivity in Infra-Red imaging. IFAC 2020 – 21st IFAC World Congress, Jul 2020, Berlin, Germany. ⟨hal-02940184⟩
60 View
123 Download
Share
