Shoreline Extraction from WorldView2 Satellite Data in the Presence of Foam Pixels Using Multispectral Classification Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Remote Sensing Année : 2020
Foam is often present in satellite images of coastal areas and can lead to serious errors in the detection of shorelines especially when processing high spatial resolution images (<20 m). This study focuses on shoreline extraction and shoreline evolution using high spatial resolution satellite images in the presence of foam. A multispectral supervised classification technique is selected, namely the Support Vector Machine (SVM) and applied with three classes which are land, foam and water. The merging of water and foam classes followed by a segmentation procedure enables the separation of land and ocean pixels. The performance of the method is evaluated using a validation dataset acquired on two study areas (south and north of the bay of Sendaï-Japan). On each site, WorldView-2 multispectral images (eight bands, 2 m resolution) were acquired before and after the Fukushima tsunami generated by the Tohoku earthquake in 2011. The consideration of the foam class enables the false negative error to be reduced by a factor of three. The SVM method is also compared with four other classification methods, namely Euclidian Distance, Spectral Angle Mapper, Maximum Likelihood, and Neuronal Network. The SVM method appears to be the most efficient to determine the erosion and the accretion resulting from the tsunami, which are societal issues for littoral management purposes.
remotesensing-12-02664-v2.pdf (4.44 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-02941791 , version 1 (17-09-2020)
Audrey Minghelli, Jérôme Spagnoli, Manchun Lei, Malik Chami, Sabine Charmasson. Shoreline Extraction from WorldView2 Satellite Data in the Presence of Foam Pixels Using Multispectral Classification Method. Remote Sensing, 2020, 12 (16), 2664 (17p.). ⟨10.3390/rs12162664⟩. ⟨hal-02941791⟩
153 Consultations
295 Téléchargements
