ASVspoof 2019: A large-scale public database of synthesized, converted and replayed speech - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Speech and Language Année : 2020
Xin Wang
Massimiliano Todisco
  • Fonction : Auteur
  • PersonId : 1199117
Andreas Nautsch
Nicholas Evans
  • Fonction : Auteur
  • PersonId : 938450
Kong Aik Lee
  • Fonction : Auteur
Lauri Juvela
  • Fonction : Auteur
Paavo Alku
  • Fonction : Auteur
Yu-Huai Peng
  • Fonction : Auteur
Hsin-Te Hwang
  • Fonction : Auteur
Yu Tsao
  • Fonction : Auteur
Hsin-Min Wang
  • Fonction : Auteur
Kai Onuma
  • Fonction : Auteur
Koji Mushika
  • Fonction : Auteur
Takashi Kaneda
  • Fonction : Auteur
Yuan Jiang
  • Fonction : Auteur
Li-Juan Liu
  • Fonction : Auteur
Ingmar Steiner
  • Fonction : Auteur
Driss Matrouf
Automatic speaker verification (ASV) is one of the most natural and convenient means of biometric person recognition. Unfortunately , just like all other biometric systems, ASV is vulnerable to spoofing, also referred to as "presentation attacks." These vulnerabilities are generally unacceptable and call for spoofing countermeasures or "presentation attack detection" systems. In addition to impersonation, ASV systems are vulnerable to replay, speech synthesis, and voice conversion attacks. The ASVspoof challenge initiative was created to foster research on anti-spoofing and to provide common platforms for the assessment and comparison of spoofing countermeasures. The first edition, ASVspoof 2015, focused upon the study of countermeasures for detecting of text-to-speech synthesis (TTS) and voice conversion (VC) attacks. The second edition, ASVspoof 2017, focused instead upon replay spoofing attacks and countermeasures. The ASVspoof 2019 edition is the first to consider all three spoofing attack types within a single challenge. While they originate from the same source database and same underlying protocol, they are explored in two specific use case scenarios. Spoofing attacks within a logical access (LA) scenario are generated with the latest speech synthesis and voice conversion technologies, including state-of-the-art neural acoustic and waveform model techniques. Replay spoofing attacks within a physical access (PA) scenario are generated through carefully controlled simulations that support much more revealing analysis than possible previously. Also new to the 2019 edition is the use of the tandem detection cost function metric, which reflects the impact of spoofing and countermeasures on the reliability of a fixed ASV system. This paper describes the database design, protocol, spoofing attack implementations, and baseline ASV and countermeasure results. It also describes a human assessment on spoofed data in logical access. It was demonstrated that the spoofing data in the ASVspoof 2019 database have varied degrees of perceived quality and similarity to the target speakers, including spoofed data that cannot be differentiated from bona fide utterances even by human subjects. It is expected that the ASVspoof 2019 database, with its varied coverage of different types of spoofing data, could further foster research on anti-spoofing.
ASVspoof2019_attacker.pdf (17.28 Mo) Télécharger le fichier
hal-02945493 , version 1 (22-09-2020)
Xin Wang, Junichi Yamagishi, Massimiliano Todisco, Héctor Delgado, Andreas Nautsch, et al.. ASVspoof 2019: A large-scale public database of synthesized, converted and replayed speech. Computer Speech and Language, 2020, 64, pp.101114. ⟨10.1016/j.csl.2020.101114⟩. ⟨hal-02945493⟩
373 Consultations
109 Téléchargements
