On a generalization of the Lebesgue's constant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2020
In this work we generalize the definition of the Lebesgue's constant to the case of field interpolation by high-order Whitney's forms on simplices. We underline the important theoretical concepts at play.
AlonsoRapetti_hal.pdf (272.49 Ko) Télécharger le fichier
hal-02946321 , version 1 (08-10-2020)
Ana Alonso Rodríguez, Francesca Rapetti. On a generalization of the Lebesgue's constant. Journal of Computational Physics, 2020, ⟨10.1016/j.jcp.2020.109964⟩. ⟨hal-02946321⟩
304 Consultations
191 Téléchargements
