Proving array properties using data abstraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a framework to abstract data structures within Horn clauses that allows abstractions to be easily expressed, compared, composed and implemented. These abstractions introduce new quantifiers that we eliminate with quantifier elimination techniques [3]. Experimental evaluation show promising results on classical array programs [16].
nsad2020-paper5.pdf (730.31 Ko) Télécharger le fichier
hal-02948081 , version 1 (24-09-2020)
hal-02948081 , version 2 (16-11-2020)
  • HAL Id : hal-02948081 , version 1
Julien Braine, Laure Gonnord. Proving array properties using data abstraction. Numerical and Symbolic Abstract Domains (NSAD), Nov 2020, Virtual, United States. ⟨hal-02948081v1⟩
79 Consultations
140 Téléchargements
