Total-velocity-based finite volume discretization of two-phase Darcy flow in highly heterogeneous media with discontinuous capillary pressure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2021
Konstantin Brenner
  • Fonction : Auteur
  • PersonId : 993083
Jerome Droniou
Roland Masson
This work proposes a finite volume scheme for two-phase Darcy flow in heterogeneous porous media with different rock types. The fully implicit discretization is based on cell centered as well as face centered degrees of freedom in order to capture accurately the nonlinear transmission conditions at different rock type interfaces. These conditions play a major role in the flow dynamics. The scheme is formulated with natural physical unknowns avoiding the cumbersome use of the global pressure. It combines a Two-Point Flux Approximation of the gradient normal fluxes with a Hybrid Upwinding approximation of the transport terms. The convergence of the scheme to a weak solution is established taking into account discontinuous capillary pressure at different rock type interfaces and the degeneracy of the phase mobilities. Numerical experiments show the additional robustness of the proposed discretization compared with the classical Phase Potential Upwinding approach.
TPFA-HU-TwoPhase-Heterogeneous.pdf (1.08 Mo) Télécharger le fichier
hal-02957054 , version 1 (04-10-2020)
hal-02957054 , version 2 (25-02-2021)
Konstantin Brenner, Jerome Droniou, Roland Masson, El Houssaine H Quenjel. Total-velocity-based finite volume discretization of two-phase Darcy flow in highly heterogeneous media with discontinuous capillary pressure. IMA Journal of Numerical Analysis, 2021, ⟨10.1093/imanum/drab018⟩. ⟨hal-02957054v2⟩
231 Consultations
167 Téléchargements
