Diversity-Preserving K-Armed Bandits, Revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We consider the bandit-based framework for diversity-preserving recommendations introduced by Celis et al. (2019), who approached it mainly by a reduction to the setting of linear bandits. We design a UCB algorithm using the specific structure of the setting and show that it enjoys a bounded distribution-dependent regret in the natural cases when the optimal mixed actions put some probability mass on all actions (i.e., when diversity is desirable). Simulations illustrate this fact. We also provide regret lower bounds and briefly discuss distribution-free regret bounds.
FairBandits-ALT20.pdf (1.4 Mo) Télécharger le fichier
hal-02957485 , version 1 (05-10-2020)
hal-02957485 , version 2 (05-04-2024)
Hédi Hadiji, Sébastien Gerchinovitz, Jean-Michel Loubes, Gilles Stoltz. Diversity-Preserving K-Armed Bandits, Revisited. 2020. ⟨hal-02957485v1⟩
310 Consultations
105 Téléchargements
