An overview of Geometry plus Simulation Modules
We give an overview of the open-source library "G+Smo". G+Smo is a C++ library that brings together mathematical tools for geometric design and numerical simulation. It implements the relatively new paradigm of isogeometric analysis, which suggests the use of a unified framework in the design and analysis pipeline. G+Smo is an object-oriented, cross-platform, fully templated library and follows the generic programming principle, with a focus on both efficiency and ease of use. The library aims at providing access to high quality, open-source software to the community of numerical simulation and beyond.
Format : Figure, Image
