A Unified Framework for Double Sweep Methods for the Helmholtz Equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We consider sweeping domain decomposition preconditioners to solve the Helmholtz equation in the case of stripwise domain decomposition with or without overlaps. We unify their derivation and convergence studies as Jacobi, Gauss-Seidel or Symmetric Gauss-Seidel for different numbering of the unknowns. This enables the theoretical comparisons of the double sweep methods in Nataf et al. (1997) with that of Vion et al. (2014). It also makes possible the introduction of two new sweeping algorithms. We provide numerical test cases that assess the validity of the theoretical studies.
articleJCP.pdf (5.23 Mo) Télécharger le fichier
hal-02964033 , version 1 (26-10-2020)
hal-02964033 , version 2 (28-01-2021)
hal-02964033 , version 3 (16-10-2022)
hal-02964033 , version 4 (04-12-2023)
Nacime Bouziani, Frédéric Nataf. A Unified Framework for Double Sweep Methods for the Helmholtz Equation. 2021. ⟨hal-02964033v2⟩
282 Consultations
131 Téléchargements
