Safe Geometric Speed Planning Approach for Autonomous Driving through Occluded Intersections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autonomous driving in urban environment needs to anticipate a number of dangerous events, such as the presence of moving vehicles in occluded areas. This paper presents an approach computing a safe motion along a fixed path in an urban environment with dynamic vehicles that may be occluded. The method works on the time-path space and uses a visibility graph to compute the speed profile, considering both safety and comfort. Evaluations performed on CARLA simulator on several typical scenarios show that the approach is able to drive safely in presence of hidden obstacles.
main.pdf (825.15 Ko) Télécharger le fichier
hal-02967740 , version 1 (15-10-2020)
hal-02967740 , version 2 (19-10-2020)
  • HAL Id : hal-02967740 , version 2
Renaud Poncelet, Anne Verroust-Blondet, Fawzi Nashashibi. Safe Geometric Speed Planning Approach for Autonomous Driving through Occluded Intersections. ICARCV 2020 - 16th International Conference on Control, Automation, Robotics and Vision, Dec 2020, Shenzhen, China. ⟨hal-02967740v2⟩
121 Consultations
304 Téléchargements
