Maxwell's equations with hypersingularities at a conical plasmonic tip - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this work, we are interested in the analysis of time-harmonic Maxwell's equations in presence of a conical tip of a material with negative dielectric constants. When these constants belong to some critical range, the electromagnetic field exhibits strongly oscillating singularities at the tip which have infinite energy. Consequently Maxwell's equations are not well-posed in the classical $L^2$ framework. The goal of the present work is to provide an appropriate functional setting for 3D Maxwell's equations when the dielectric permittivity (but not the magnetic per-meability) takes critical values. Following what has been done for the 2D scalar case, the idea is to work in weighted Sobolev spaces, adding to the space the so-called outgoing propagating singularities. The analysis requires new results of scalar and vector potential representations of singular fields. The outgoing behaviour is selected via the limiting absorption principle.
BoChRi.pdf (1.55 Mo) Télécharger le fichier
hal-02969739 , version 1 (16-10-2020)
hal-02969739 , version 2 (22-12-2021)
  • HAL Id : hal-02969739 , version 1
Anne-Sophie Bonnet-Ben Dhia, Lucas Chesnel, Mahran Rihani. Maxwell's equations with hypersingularities at a conical plasmonic tip. 2020. ⟨hal-02969739v1⟩
314 Consultations
185 Téléchargements
